Hallo!
kam zu gast zu den nachbarn vorbei.... original zustand:
![](https://www.hecktrieb.de/hkwcf/images/avatars/85/517-855edfd6ad3f960ab1eeafd7d440830eddf493b5.jpg)
Finnische 26m
hi roman!
schönes auto!
datscha fertig?
Hi!
All has become complicated.
2 weeks ago wished to clean a place and to dig a holes for the fundaments...
The dredge has sunk in the ground....in loss of half of day we it pulled out.
It has appeared that a nearest stream channel have closed, for expansion of kitchen gardens,
And the stream flows now underground everywhere. Now ground waters 30cm from a surface.
Now it is necessary to dig by-pass ditches for drainage, and to clear a stream channel.
And still it is necessary to take somewhere a caterpillar dredge as our is on wheel based and 8.5 tons weigh - sinks in the water filled ground w/o problems.we have crazy hot 35 .. 42 С
There is hot I want to completely sanding my Fordhi roman!
schönes auto!
datscha fertig?
8| uhhhh... sounds bad. or "interesting" :D depending on the perspective...
if you need another CAT, ask 16V-Hexe ;) he is CATwoman. ^^
hi!
I talk about
this small, it would be easy to pull out if he gets stuck in our swamps.
actually, my direct involvement there while not required
Although the tractor, I also pulled out. :Dto us now, you can easily go to a spa, I think, even in Greece is not so warm.
I still took a tractor - pulled excellent mud bath for free... :)8| uhhhh... sounds bad. or "interesting" :D depending on the perspective...
thank you very much
Hurra!
Freischwimmkurs für Scania & co. -
Ja, gut
DAS INSTRUKTION:...
Wunderbar, aber uralt und ein Fake!
Auf dem Bild, wo der grüne Kran fällt, stehen exakt die selben Personen in den exakt gleichen Positionen, wie auf dem Bild, wo der kleine Kran im Wasser liegt. Ausserdem stehen diese Personen genau dort, wo vermeintlich Sekundenbruchteile vorher noch der grüne Kran gestanden hat....
Und die "Retuschierwolke" vor dem Kran, mit der die Zuschauergruppe an der Ecke der Landzunge verschwinden mußte.Der blaue Kran ist der umgefärbte grüne Kran und ausserdem liegt der kleine Kran auf dem Bild zweimal im Wasser.
Und ganz ausserdem ist der Scania ein Volvo!
natürlich :)
