Motor 2,8 im P7. etwas falsch.
  • Hallo!
    1. Vorstellungen über die Lage der Riemen auf die Riemenscheiben. wahrscheinlich hinzufügen zu einer zusätzlichen Scheibe...
    2. installiert man den Lüfter ist nicht genug 2 Zentimeter. legte elektrische vor dem Kühler? :(
  • Hi Roman,
    die Wasserpumpe ist für den P7 zu lang. Die richtige ist die EPW 980.
    Bei Bedarf mach ich grad ein Bild von meinem Motor.
  • Wasserpumpe hätte ich noch original Motorcraft hier...
    LG Ralf
  • Hi Roman,
    thanks for answers!
    My:
    EPW980, etc
    Timing cover are different: 1540085 74TM 6019 AA vs 6105293 83TM 6019 BA
    My motor is PRE ('85), with:
    PRE cyl. block
    PRE cyl. heads
    Oil pan from P7
    cyl. heads covers from P7
    timing cover from PRE
    cylinders & crankshaft, etc PRE
    camshaft: carb custom "for road" (http://www.rallyracefin.fi/for…/Moottori%20V6%20Koln.pdf)
    carb plate: Granada 2.8
    carb: Weber 38DGAS
    fuel pump: high pressure, with back line
    oil pump: orig
    oil intake: custom
    also: bigger radiator, with pipes for automatic gearbox. oil kuhler.
    & this frankenstain works w/o problems.
    I have no ideas, possibly need to change timing cover, but I don't know what cover can be used with "thick crankshaft"
    possibly Sierra 2.3 ~'87?
  • I have no ideas, possibly need to change timing cover, but I don't know what cover can be used with "thick crankshaft"
    You must insert the forehead wheel lid from 2.3 with climate or from 2.8.
  • Your water pump is easy too long.
    In addition ask I me, which is why you have obstructed the double wheels.
    I have merely on the crankshaft a double and on top on the right in the lid the Umlenkrolle.
    only this pump fits on PRE timing cover. possibly to change timing cover, but I don't know about compatibility.
    Pulleys also can be taken with timing cover from diff. motor - sierra 2.3 '87?
    also, I can make new pulleys. but problem only in pump length.
    timing cover from Granada not compatible due to crankshaft fitting.
  • You need the lid of 2.8 or 2.3 with climate. They fit on the crankshaft.
    In addition then the water pump EPW 980.
    Dem Nick zieh ich bei Gelgenheit die Ohren lang... :uwe:
    hm, okay, now I understand. motor would be so even now to find ...
    Nick is still suffering by the finger ;)
  • Hallo!
    wie in der deutschen heißt, die ich brauche?
    timing cover and pulley of thick crankshaft, pump pulley.
    timing cover- Stirnraddeckel or Steuergehäusedeckel
    pulley of thick crankshaft- Riemenscheibe Kurbelwelle
    pump pulley - Riemenscheibe Wasserpumpe
    ...i guess..... ;-)
  • Впрочем, ты имеешь прекраÑную машину и Ñкоро также правильный мотор.
    Das hab ich auch mal versucht...
    очень бы того хотелоÑÑŒ.
    Ja, und ich kann lesen CP1252. :catch:
  • Ah ok,
    but it works just for you and not andersrum i think ;)
    Hey but i think you have to make some Rostpflege on your P7 weil i think its very salty there when Snowfall is hä?
  • Ah ok,
    yes, I understand same encryption w/o problems :)
    now I hastily try to fit different parts: the motor, g.box, etc. - to do some welding works. after, P7 body ready for sanding & priming.
  • yes, I understand same encryption w/o problems :)
    Yeah anyway its good to see that there is a P7 running(or running in the future) in Russia.
    Hope you find the way with your P7 to Germany some day and hope you keep us informed about your progress with the car :thumbsup:
  • Yeah anyway its good to see that there is a P7 running(or running in the future) in Russia.
    despite the disaster with my time, the information appears on homepage, below the signature.
    I want to do everything as possibly by myself, well, just pay the money for to do all is not interesting, it's my toy :)
    no problems with the trips to Germany, the problem with the time for Ford building :/
