Hallo!
on my flange wear along to o-ring.
as I understand that this part is standardized, but I have no catalogs.
compatibility?
picture as an example.
Hallo!
compatibility?
sorry, what do you need? Do you need the flange or the radial shaft seal?
Hallo Ben! Thanks for caring!
Flange.
Flange, by possibly. Both, I unscrewed from the r.a. - have wear on the "seal surface".
Thanks for the answer!
Me messages usually ignore here :D
the flange i have in used condition, i present it you, you only need to pay the shipping costs.
But be warned, its very oily and dirty ![]()
Faulpelz...
Said the hairy man ![]()
Hallo Ben!
superdank!
this is not a problem. I also think of what to send you as gift, in retaliation ;)
at weekend I make some photos, for compare - may be your part not a better than mein.
of oil and dirty do not worry, I'm not afraid. and I have a compressor and sand blaster.
UPD
tame bears does not accept for shipment at the post office.
in Suomi the same problem - mad elks are also will not be accepted to be sent.
UPD
0.1mm wear groove
